Quartus copied content from IP directory then reported permission error
Thanks for replying.
1. I looked at the license file and it appeared to be a 3-month eval license. That may explain why the users haven't asked for additional directories to add write permission.
# Floating Server License
# Primary Machine Name-coflic06
# Primary Machine ID-NIC ID E41F13630800
# Redundant Server 2-N/A
# Redundant Server 3-N/A
# Product License Summary:
# 1 Intel® Quartus® Prime Software 90-Day Evaluation (Standard and Pro Editions) (License: EVALUATION-LIC), 2 Seat(s)
# - Maintenance Expiration of 2024.08
# - License Expires 07-Aug-2024
2. I don't know how to answer that. I just relay what I was told - that the issue didn't happen on v23 but on v24.1. If you are saying Quartus does not have a routine that does a copy process from the IP install area to the /tmp area, inheriting the owner's permission, I will have to ask the original user submitting the ticket on your side and mine to work with you. Then again, your support system is so difficult to work with, it took almost 2 months to reach this point, I suspect the eval would have expired before we can get to the bottom of this.
