Quartus compiler parameter expression evaluation with power operator (A**) faulty?
- 3 years ago
Verilog LRM says
"Implementations may limit the maximum size of integer variables, but it shall be at least 32 bits."You see that Quartus apparently uses 32 bit integer but Modelsim most likely 64 bit. That's completely legal but must be considered.
Quartus gives an overflow warning for line 10, by the way.
The rest shouldn't happen according to Verilog language reference, I think. Looks a bug in parameter calculation, ignoring type proagation rules for real parameters.
This worked for me in Quartus 19.1localparam PHASE_RATE_5 = real'(F_C_HZ)/real'(F_S_HZ) * real'(2.0**N_BITS);
We have not received a reply from you. As such, I now transition this thread to community support. If you have a new question, Feel free to open a new thread or login to ‘ https://supporttickets.intel.com ’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Have a great day!
Nurina W.
