16 years agoOpen You Quartus Project
Menue Assignments -> Settings Compilation Process Settings choose Parallel compilation . Use all available processors enable Use smart compilation Fitter Settings Set fitter effort to Auto Fit your system should be fast enough a Cyclone II EP2C70 design with ~70% usage is compiled here on a E8500 cpu within 50 minutes. Is your project stored localy or via network ?
