Quartus CLI cpf Error 213035
Quartus 18.0
When trying to use the CLI to convert a sof file to a jic file, I receive an error stating that the "Error (213035): Configuration device MT25QL256 is illegal".
quartus_cpf -c -d MT25QL256 -s 5CEBA4 Test.sof Test.jic
I changed the device to EPCQ128A and it creates the jic file successfully.
quartus_cpf -c -d EPCQ128A -s 5CEBA4 Test.sof Test.jic
I modified the qsf:
set_global_assignment -name USE_CONFIGURATION_DEVICE OFF
And received the same message.
The answer is in Article ID: 000076544. Essentially, in Quartus versions prior to 18.1 you need to create a quartus.ini file with the contents pgm_allow_mt25q=on. The other important piece of information is the quartus.ini file should reside in the bin64 folder for CLI to include the MT25Q configuration devices.
Once these pieces are in place, you can successfully create a programming file through the command line interface.
Howard
- NurAiman_M_Intel
Have you try to generate the .jic file using Quartus GUI? Is it working?
Also, can you try to use the latest Quartus version?
Aiman
- HB4
Yes, it generates the jic file from within Quartus GUI environment.
Howard
- HB4
Additional details that might be helpful.
If you launch Quartus and then select "Convert Programming Files..." without opening a project, the list of configuration devices is a smaller collection and does not show the MT25QL256.
Opening a project somehow loads additional configuration devices. Does this sound reasonable? How would I do this through CLI?
Howard
- HB4
Howard
- NurAiman_M_Intel
Thank for sharing with us.
