Quartus CLI cpf Error 213035
- 3 years ago
The answer is in Article ID: 000076544. Essentially, in Quartus versions prior to 18.1 you need to create a quartus.ini file with the contents pgm_allow_mt25q=on. The other important piece of information is the quartus.ini file should reside in the bin64 folder for CLI to include the MT25Q configuration devices.
Once these pieces are in place, you can successfully create a programming file through the command line interface.
Howard
Additional details that might be helpful.
If you launch Quartus and then select "Convert Programming Files..." without opening a project, the list of configuration devices is a smaller collection and does not show the MT25QL256.
Opening a project somehow loads additional configuration devices. Does this sound reasonable? How would I do this through CLI?
Howard
- HB43 years ago
Howard
