8 years agoquartus_cdb 17.1.0 crashes while generating vqm file
Hi All,
quartus_cdb crashes while generating vqm file. Please let me know if there is any solution I am synthesizing simple adder as follows module saxo_light_Add_24Ux24U_24U_4 ( in2, in1, out1 ); input [7:0] in2; input [7:0] in1; output [7:0] out1; assign out1 = in2 + in1; endmodule The tcl command is as follows: load_package flow load_package report load_package sdc set module "saxo_light_Add_24Ux24U_24U_4" set num 2 set family "StratixV" proc syn { module family verilogInput} { set proj [project_new -overwrite ./$module] set_global_assignment -name FAMILY $family set_global_assignment -name DEVICE Auto set_global_assignment -name VERILOG_FILE saxo_light_Add_24Ux24U_24U_4.input.v set_instance_assignment -name VIRTUAL_PIN ON -to in* set_instance_assignment -name VIRTUAL_PIN ON -to out* set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top execute_module -tool map execute_module -tool fit execute_module -tool cdb -args "--vqm=${module}.vqm" } syn $module $family $module quartus_cdb crashes resulting with following info. Info: ******************************************************************* Info: Running Quartus Prime Compiler Database Interface Info: Version 17.1.0 Build 590 10/25/2017 Info: Processing started: Fri May 11 02:20:43 2018 Info: Command: quartus_cdb saxo_light_Add_24Ux24U_24U_4 -c saxo_light_Add_24Ux24U_24U_4 --vqm=saxo_light_Add_24Ux24U_24U_4.vqm Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance. Info (203002): Generated Verilog Quartus Mapping File using post-fit netlist *** Fatal Error: Segment Violation at (nil) Module: quartus_cdb Stack Trace: 0xbbd90: DEV_DEVICE::get_pad_info() const (ddb_dev) End-traceNo RepliesBe the first to reply
