- James_B
Contributor
Nurina, The basic_data_types.vhd file is included in github now.
The design takes approximately 10 minutes to compile.
Also, if you want to see the uart readout, you need to add a small FTDI usb uart to the gpio pins GPIO_9 (Rx) and GPIO_11 (Tx)
Thanks, James
- Nurina
Thanks James. I am able to replicate the problem you're seeing. I've reported the problem to engineering and will let you know of any updates.
Nurina
- James_B
Contributor
Thanks for the feedback Nurina. Will look for future updates. James
- Nurina
Hi James,
I'd just like to let you know that our engineering team is currently investigating the problem. I will let you know if there are any further updates.
Nurina
- James_B
Contributor
Nurina, Thanks for the feedback. I have a large codebase that I inherited with these issues, with this function scattered through out the code base. If there is some sort of fix, it would be most valuable to a current design effort. Also if the engineering team needs anything from me just let me know. Thanks. James
- Nurina
Hi James,
Just to let you know that our engineering are now focusing feature enhancement/bug fixing on Pro edition. For Standard edition, they will put it as lower priority. We are sorry to inform this.
With that, I shall put this case to a close pending. If you still need further assistance, you are welcome reopen this case within 15 days or open a new case, and someone will help you.
Nurina
- James_B
Contributor
Nurina,
Regarding the feedback here, is it true that the engineering team will be addressing the VHDL function overloading issue with the Pro Edition, or a general list of issues/bugs that does not include the overloading issue?
James
