HMS03049
3 years agoQuartus 9.x or other for the MAX EPM9560
We are supporting an old system which uses the EPM9560a. Background: We have the .pof file It is a large system, the function of the CPLD PCB is not defined sufficiently for redesign using a newer...
_AK6DN_
3 years ago1) If you have the .qdz file, and did not rename it, it should have the version number of Quartus it belongs to.
To my knowledge you cannot move .qdz files between versions of Quartus.
2) Someone else will have to answer that ...
3) Have you tried using the Quartus 13.0sp1 standalone programmer with a USB Blaster to see if it supports your device?
