16 years agoWell I don't use the 64-bit version. But the 32-bit version is around 6GB. Are you sure those numbers are correct? By the way all of those last files are java. They are not viruses.
JakeWell I don't use the 64-bit version. But the 32-bit version is around 6GB. Are you sure those numbers are correct? By the way all of those last files are java. They are not viruses.
Jake
