10 years agoQuartus 9.1 installation problem on W10
I am trying to install Quartus 9.1 service pack2 we edition on W10. Getting this error: http://www.alteraforum.com/forum/attachment.php?attachmentid=12084&stc=1 How can I solve it? Thanks6 Replies
Quartus 9.1 Only Supports windows XP - so you will either need to run it in a VM or get the linux version.
Quartus 9.1 works on my windows 7 PC.
Edit: That should be Quartus 9.1 service pack 2. - Altera_Forum
--- Quote Start --- Quartus 9.1 Only Supports windows XP - so you will either need to run it in a VM or get the linux version. --- Quote End --- Will the linux version just work on my Windowns 10? or any special adjustments needed? - Altera_Forum
The linux version needs to be run on linux, but you could run this in a VM on windows 10, or via a dual boot.
stop spending time on outdated version.
--- Quote Start --- stop spending time on outdated version. --- Quote End --- If the user has an older device, like a cyclone or flex 10k, then they have no choice this is the latest version to support the old devices. Migrating to a newer version is not always possible.
