16 years agoQuartus 8.1 String-Parameter with Block Symbols
Hey @ all!
This is a little bit crazy. I'm using the graphical surface with Quartus. Some VHDL entitys are using generics. Some generics are from the type "String". Inside the VHDL code I parse the String with '=' to generate my code. Everything was fine with Version 7.2 and lower. Last week I updated to QII 8.1 and my project wasn't working any more. I found out, that QII 8.1 deletes the first and last character from my String. But this only happens when I have edited the String. When the String is not changing, everything is still fine. Does anyone has this problem, too? Is there maybe a workaround?
