18 years agoand it gets even WORSE !
if i swap the 'Z' assigment and the next line :
This :
cs = 1'bz; // tristate CS
selected = (cs & enable ); // incoming CS signal AND 'enable'
change to:
it DOES compile correctly ! This is a mayor problem. I have a complex block where,depending on a bunch of control signals i switch this tristate driver either hard to zero , hard to 1 , under control of a logic equasion
cs=1'bz; // by default we are 'z'
if (condition) begin
case (state) // except ...
case 4'b1100 : cs = something;
case 4'b0000 : cs = something_else
case 4'b1010 : cs = 1'b0;
case 4'b1101 : cs = 1'b1;
case 4'b1110 : begin
if yadayada then cs = 1'b1;
else cs = 1'bz;
end
case 4'b1001 : begin
if so_and_so then cs = this;
else cs = 1'bz;
end
default : cs = 1'bz;
end
endcase
( the real decision block is even more complex since there are a lot more sub 'case statements' that decide on the state of CS ) Why does this not work? this is normal scheduled code.... its 'z' excpet if so and so and this and that ... or does scheduling not work in this case ?
