TomCarpenter
2 years agoQuartus 22.1std Access Violation quartus_map.exe Stratix V
Hi, When compiling a project for a Stratix V device using Quartus 22.1std on a Windows 10 machine. The design uses multiple design partitions including two which contain UniPHY memory controllers in...
TomCarpenter
2 years agoA little bit of further information. It appears to be related to a partition containing a NIOS II processor. That is the only one that fails synthesis. Quartus just reports that it did not complete due to errors but gives no error messages - just the access violation popup.
However the exact same Qsys system generated for an Arria 10 device compiles fine. So it shouldn't be a design issue, but rather some Quartus problem.
yanlalalala
2 years agoHi,
Please try to use command to compile.
Fatal Error: Access Violation at 00007FF943D50950 (intel.com)
