srinivask's avatar
srinivask
4 years ago
Quartus 22.1 crashes when using "Change File" with Programmer
Hi
I am using Quartus 22.1 software with Stratix 10 FPGA. I am successfully able to connect to the board using Quartus SW and also with the BTS utility. However when I try to change the File (see snapshot below) , it crashes immediately.
Can you please advise a fix for the same ?
I am using Windows11 computer. I am using USB on the board to the PC with JTAG scan chain mode.
regards
Srinivas
  • srinivask's avatar
    srinivask
    4 years ago
    The solution that worked was to disable One Drive syncing the desktop. Once I disabled One Drive sync of Desktop folder, it solved the problem. Please publish this solution.
  • Farabi_Altera's avatar
    Farabi_Altera
    You might need to use latest Quartus to get support on Windows 11 platform.
    regards,
    Farabi
      srinivask
      The culprit is the One Drive Sync. Just disable Desktop sync in One Drive and every thing works like a charm.
  • We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
      srinivask
