srinivask
4 years agoQuartus 22.1 crashes when using "Change File" with Programmer
Hi
I am using Quartus 22.1 software with Stratix 10 FPGA. I am successfully able to connect to the board using Quartus SW and also with the BTS utility. However when I try to change the File (see ...
- 4 years ago
The solution that worked was to disable One Drive syncing the desktop. Once I disabled One Drive sync of Desktop folder, it solved the problem. Please publish this solution.
Farabi_Altera
4 years agoHello,
You might need to use latest Quartus to get support on Windows 11 platform.
regards,
Farabi
- srinivask4 years ago
The culprit is the One Drive Sync. Just disable Desktop sync in One Drive and every thing works like a charm.
