srinivask
4 years agoQuartus 22.1 crashes when using "Change File" with Programmer
Hi
I am using Quartus 22.1 software with Stratix 10 FPGA. I am successfully able to connect to the board using Quartus SW and also with the BTS utility. However when I try to change the File (see ...
- 4 years ago
The solution that worked was to disable One Drive syncing the desktop. Once I disabled One Drive sync of Desktop folder, it solved the problem. Please publish this solution.
NurAiman_M_Intel
4 years agoWe do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
srinivask
4 years agoThe solution that worked was to disable One Drive syncing the desktop. Once I disabled One Drive sync of Desktop folder, it solved the problem. Please publish this solution.
