MartinE
3 years agoQuartus 21.1 devices troubles
Hi, I installed the 21.1, the last version that support MAX V devices. When I make a new project I can't select the devices, it not appear any device. Then I try install the MAX V devices and I get ...
MartinE
3 years agoHi Nurina,
I don't know about if there are several differences between 20.1 and 21 quartus or not.
I think is better to get a solution in the problem for prevent throubles in future.
But I think you have more experience with quartus software and I think the best solution is whatever you think is best.
Then, what do you recommend?
Martin
