Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
Hi Chandu,
As the initial issue for this thread is not showing anymore, could you create a new forum post regarding the new issue?
Error(21961): Input port OE of a "LVDS" I/O output buffer "*|gpio_0|core|i_loop[0].altera_gpio_bit_i|output_buffer.obuf_0" is not supported.
We prefer a new case for each unique technical problem, as it aids our case analysis and helps us assess our customer support requirements.
Richard Tan
Hi Richard,
I could get this error working. had to enable pad_out_n signal from GPIO IP core as my I/O standard is LVDS. currently I am getting error for pin assignments.
working on clearing the I/O assignments. will raise a new ticket if issue is not resolved at my end.
Thanks for the support,
Chandu sri
Error (20403): Global setting for OUTPUT_IO_TIMING_FAR_END_VMEAS is not supported. Please use this setting with pin assignments.
Error (20403): Global setting for OUTPUT_IO_TIMING_NEAR_END_VMEAS is not supported. Please use this setting with pin assignments.
Error (16297): An error has occurred while trying to initialize the plan stage.
Error: Quartus Prime Fitter was unsuccessful. 624 errors, 5 warnings
Error: Peak virtual memory: 3919 megabytes
Error: Processing ended: Fri Mar 13 02:55:55 2026
Error: Elapsed time: 00:01:01
Error: System process ID: 22710
Error (21794): Quartus Prime Full Compilation was unsuccessful. 626 errors, 322 warnings
Error: Flow compile (for project /prj/kratos/users/chandusr/p4v_work/62702_18_1std/kram/krpi_kraq_fpga) was not successful
Error: run_flow flow:run1 finished: 0 Failed
Error (23031): Evaluation of Tcl script /pkg/altera/quartus/25.3pro/quartus/common/tcl/internal/qsh_flowengine.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 633 errors, 322 warnings
Error: Peak virtual memory: 1240 megabytes
Error: Processing ended: Fri Mar 13 02:55:58 2026
Error: Elapsed time: 00:07:19
Error: System process ID: 6053
Error : Failed to compile
