Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
below are the errors observed in Windows version for Q25.3pro along with an System error
***System error -
Info: 2026-02-26 20:52:03 worker[0] started.
Info: Run task: Clean Project
Info: Flow will resume with task: task:dni_ipgenerate
Info: 2026-02-26 22:12:12 worker[0] started.
Info: Run task: IP Generation
Error(24222): Unable to access status db: database initialization failed.
***Processing errors -
Error: krpi_system_usb_avmm_passthru_0.usb_avmm_passthru_0: Component usb_avmm_passthru 1.0 not found or could not be instantiated
Error: Generation failed with exit code 3: 1 Error, 5 Warnings
Error: krpi_system_mem_test_avmm_passthru_0.mem_test_avmm_passthru_0: Component mem_test_avmm_passthru 1.0 not found or could not be instantiated
Error: krpi_system_acq_avmm_passthru_0.acq_avmm_passthru_0: Component acq_avmm_passthru 1.0 not found or could not be instantiated
Error: krpi_system_avmm_passthrough_monitor_0.avmm_passthrough_monitor_0: Component avmm_passthrough_monitor 1.0 not found or could not be instantiated
Error: Generation failed with exit code 3: 1 Error, 6 Warnings
Error: Quartus Prime IP Generation Tool was unsuccessful. 8 errors, 25 warnings
Error: Peak virtual memory: 334 megabytes
Error: Processing ended: Thu Feb 26 22:15:57 2026
Error: Elapsed time: 00:03:43
Error: System process ID: 33980
Error(21794): Quartus Prime Full Compilation was unsuccessful. 10 errors, 25 warnings
