Quartus 2 SignalTap2 LogicAnalyzer Trigger Condition
Any time you add debug logic to a design, you can potentially affect its operation. You're adding signal stubs which can affect timing. Does your design meet timing when running a timing analysis? Does the design function correctly if Signal Tap has not been started? Or do you have to completely remove it to make the design work correctly?
Also, the KEY signals are commented out in your top level design. Is that intentional?
And you did not include the .stp file in the .zip. It's not clear from your screenshot all the signals that are being tapped. Can you provide the complete list or the .stp?
- Lululukas3 years ago
- The Design works incorrect bevor SignalTap has been started.
- I have to remove some signals I added to the stp file. Removing the whole file is not necessary.
- That is a Leftover of an older variant. You can the declaration of the KEYs in line 9 of the top level design.
- In the Folder output_files is the stp file "aufgabe5_keys_adress_trigger.stp". Is this not the standart directory for stp files? Quartus put them there by default.
Thank you for your reply.
