10 years ago
quartus 2: can't determine definition of operator "*"
I've got this error for the following code:
library IEEE;
--use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
use IEEE.STD_LOGIC_TEXTIO.ALL;
use ieee.numeric_std.all;
--package image_array_2 is
-- type image_array is array(0 to 49, 0 to 49) of unsigned(7 downto 0);
--type image_derivadas is array(0 to 49, 0 to 49) of unsigned (8 downto 0);
--end package image_array_2;
use work.imagens.all;
entity hornteste is
Port (
clk : in bit;
imagem: in image_array;
imagemanterior: in image_array;
Ix: out image_derivadas;
Iy: out image_derivadas;
It: out image_derivadas
end hornteste;
architecture Behavioral of hornteste is
begin
process (clk)
begin
If (clk 'event and clk = '1') then
for x in imagem'range(1) loop
for y in imagem'range(2) loop
Ix(x,y) <= 1/4 * (imagemanterior(x,y+1) - imagemanterior(x,y) + imagemanterior (x+1,y+1) - imagemanterior(x+1,y) + imagem(x,y+1) - imagem(x,y)+imagem(x+1,y+1)-imagem(x,y+1));
Iy(x,y) <= 1/4*(imagemanterior(x+1,y) - imagemanterior(x,y) + imagemanterior(x+1,y+1) - imagemanterior(x,y+1) + imagem(x+1,y) - imagem(x,y) + imagem(x+1,y+1) -imagem(x,y+1));
It(x,y) <= 1/4 * (imagem(x,y) - imagemanterior(x,y) + imagem(x+1,y)- imagemanterior(x+1,y) +imagem(x,y+1)- imagemanterior(x,y+1) + imagem(x+1,y+1)- imagemanterior(x+1,y+1));
end loop;
end loop;
end if ;
end process;
end Behavioral;
I've used the unsigned type for the signals in opertation. what's wrong with it? thanks in advance.
    and the main code called hornshunck is this:
    library IEEE;
    use IEEE.STD_LOGIC_signed.ALL;
    package imagens is
    type image_array is array(0 to 49, 0 to 49) of signed(8 downto 0);
    type image_derivadas is array(0 to 49, 0 to 49) of signed (9 downto 0);
    type image_19bits is array (0 to 49, 0 to 49) of signed (18 downto 0);
    end imagens;
    --type image_array is array(0 to 49, 0 to 49) of unsigned(7 downto 0);
    entity hornschunk is
    Port ( clk_0 : in bit;
    ukfinal : out image_19bits ;
    vkfinal: out image_19bits
    end hornschunk;
    architecture Behavioral of hornschunk is
    signal entrada, entradaanterior : image_array;
    signal Ix_0,Iy_0,It_0, dividendo_0 : image_derivadas;
    signal divisor_0, uk_0, vk_0: image_19bits;
    signal mediau_0, mediav_0, uk2_0, vk2_0,uk3_0,vk3_0, mediau2_0,mediav2_0,dividendo2_0,dividendo3_0: image_19bits;
    --signal uk_0,vk_0,uk_1,vk_1,divisor_0 : SIGNED (32499 downto 0) ;
    component inicializacao port(
    clk: in bit;
    imagem: out image_array;
    imagemanterior: out image_array
    ); end component;
    --*component inicializacao port(
    -- clk: in bit;
    -- imagem: out SIGNED (19999 DOWNTO 0);
    -- imagemanterior: out SIGNED (19999 DOWNTO 0)
    -- ); end component;
    component stage_1 port(
    clk: in bit ;
    imagem : in image_array;
    Iy : out image_derivadas;
    It : out image_derivadas
    ); end component;
    --component stage_1 port(
    -- clk: in bit ;
    -- imagem: in SIGNED (19999 DOWNTO 0);
    -- imagemanterior: in SIGNED (19999 DOWNTO 0);
    -- Ix: out SIGNED (3 DOWNTO 0);
    -- Iy : out SIGNED (3 DOwNTO 0);
    -- It : out SIGNED (3 DOWNTO 0)
    component stage_2
    port(
    clk: in bit;
    Ix: in image_derivadas;
    Iy: in image_derivadas;
    It: in image_derivadas;
    divisor: out image_19bits;
    dividendo: out image_derivadas
    --uk:out SIGNED (9999 DOWnTO 0);
    --vk:out SIGNED (9999 DOWNto 0)
    ); end component;
    component first_iteration
    port(
    clk : in bit;
    divisor: in image_19bits;
    dividendo: in image_derivadas;
    --uk: in SIGNED (9999 DOWNTO 0);
    --vk: in SIGNED (9999 DOWNTO 0);
    uk1: out image_19bits;
    vk1: out image_19bits
    ); end component;
    component medias_1
    port(
    clk: in bit;
    uk1: in image_19bits;
    vk1: in image_19bits;
    mediau: out image_19bits;
    mediav: out image_19bits
    ); end component;
    component second_stage_2
    port(
    clk: in bit;
    mediau: in image_19bits;
    mediav: in image_19bits;
    dividendo2: out image_19bits
    ); end component;
    component second_iteration
    port(
    clk: in bit;
    dividendo2: in image_19bits;
    uk2: out image_19bits;
    vk2: out image_19bits
    ); end component;
    component medias_2
    port(
    clk: in bit;
    uk2: in image_19bits;
    vk2: in image_19bits;
    mediau2: out image_19bits;
    mediav2: out image_19bits
    ); end component;
    component third_stage_2
    port(
    clk: in bit;
    mediau2: in image_19bits;
    mediav2: in image_19bits;
    dividendo3: out image_19bits
    ); end component;
    component third_iteration
    port(
    clk: in bit;
    dividendo3: in image_19bits;
    uk3: out image_19bits;
    vk3: out image_19bits
    ); end component;
    begin
    U1: inicializacao PORT MAP (
    clk=> clk_0,
    imagem=> entrada,
    imagemanterior => entradaanterior
    U2: stage_1 PORT MAP (
    clk => clk_0,
    imagem =>entrada,
    imagemanterior => entradaanterior,
    Ix=> Ix_0,
    Iy=>IY_0,
    It=>IT_0
    U3: stage_2 PORT MAP (
    clk => clk_0,
    Ix =>Ix_0,
    Iy =>Iy_0,
    It => It_0,
    divisor => divisor_0,
    dividendo => dividendo_0
    U4: first_iteration PORT MAP (
    clk => clk_0,
    dividendo => dividendo_0,
    Ix => Ix_0,
    Iy=> Iy_0,
    uk1 => uk_0,
    vk1 => vk_0
    --uk1 => ukfinal,
    --vk1 => vkfinal
    U5: medias_1 PORT MAP(
    clk => clk_0,
    uk1 => uk_0,
    vk1 => vk_0,
    mediau => mediau_0,
    mediav =>mediav_0
    U6: second_stage_2 PORT MAP(
    clk => clk_0,
    Ix => Ix_0,
    Iy => Iy_0,
    It => It_0,
    mediau => mediau_0,
    mediav => mediav_0,
    dividendo2 => dividendo2_0
    U7: second_iteration PORT MAP(
    clk => clk_0,
    dividendo2 => dividendo2_0,
    mediau => mediau_0,
    mediav => mediav_0,
    Ix => Ix_0,
    Iy => Iy_0,
    uk2 => uk2_0,
    vk2 => vk2_0
    U8: medias_2 PORT MAP(
    clk => clk_0,
    uk2 => uk2_0,
    vk2 => vk2_0,
    mediau2 => mediau2_0,
    mediav2 =>mediav2_0
    U9: third_stage_2 PORT MAP(
    clk => clk_0,
    Ix => Ix_0,
    Iy => Iy_0,
    It => It_0,
    mediav2 => mediav2_0,
    dividendo3 => dividendo3_0
    U10: third_iteration PORT MAP(
    clk => clk_0,
    dividendo3 => dividendo3_0,
    Ix => Ix_0,
    Iy => Iy_0,
    uk3 => uk3_0,
    vk3 => vk3_0
    end behavioral;
