10 years agoquartus 2: can't determine definition of operator "*"
I've got this error for the following code: library IEEE; --use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_unsigned.ALL; use IEEE.STD_LOGIC_TEXTIO.ALL; use...
10 years agoand the main code called hornshunck is this:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_signed.ALL; use IEEE.STD_LOGIC_TEXTIO.ALL; use ieee.numeric_std.all; package imagens is type image_array is array(0 to 49, 0 to 49) of signed(8 downto 0); type image_derivadas is array(0 to 49, 0 to 49) of signed (9 downto 0); type image_19bits is array (0 to 49, 0 to 49) of signed (18 downto 0); end imagens; use work.imagens.all; --type image_array is array(0 to 49, 0 to 49) of unsigned(7 downto 0); entity hornschunk is Port ( clk_0 : in bit; ukfinal : out image_19bits ; vkfinal: out image_19bits ); end hornschunk; architecture Behavioral of hornschunk is signal entrada, entradaanterior : image_array; signal Ix_0,Iy_0,It_0, dividendo_0 : image_derivadas; signal divisor_0, uk_0, vk_0: image_19bits; signal mediau_0, mediav_0, uk2_0, vk2_0,uk3_0,vk3_0, mediau2_0,mediav2_0,dividendo2_0,dividendo3_0: image_19bits; --signal uk_0,vk_0,uk_1,vk_1,divisor_0 : SIGNED (32499 downto 0) ; component inicializacao port( clk: in bit; imagem: out image_array; imagemanterior: out image_array ); end component; --*component inicializacao port( -- clk: in bit; -- imagem: out SIGNED (19999 DOWNTO 0); -- imagemanterior: out SIGNED (19999 DOWNTO 0) -- ); end component; -- */ component stage_1 port( clk: in bit ; imagem : in image_array; imagemanterior: in image_array; Ix: out image_derivadas; Iy : out image_derivadas; It : out image_derivadas ); end component; --component stage_1 port( -- clk: in bit ; -- imagem: in SIGNED (19999 DOWNTO 0); -- imagemanterior: in SIGNED (19999 DOWNTO 0); -- Ix: out SIGNED (3 DOWNTO 0); -- Iy : out SIGNED (3 DOwNTO 0); -- It : out SIGNED (3 DOWNTO 0) -- ); end component; component stage_2 port( clk: in bit; Ix: in image_derivadas; Iy: in image_derivadas; It: in image_derivadas; divisor: out image_19bits; dividendo: out image_derivadas --uk:out SIGNED (9999 DOWnTO 0); --vk:out SIGNED (9999 DOWNto 0) ); end component; component first_iteration port( clk : in bit; divisor: in image_19bits; dividendo: in image_derivadas; Ix: in image_derivadas; Iy: in image_derivadas; --uk: in SIGNED (9999 DOWNTO 0); --vk: in SIGNED (9999 DOWNTO 0); uk1: out image_19bits; vk1: out image_19bits ); end component; component medias_1 port( clk: in bit; uk1: in image_19bits; vk1: in image_19bits; mediau: out image_19bits; mediav: out image_19bits ); end component; component second_stage_2 port( clk: in bit; Ix: in image_derivadas; Iy: in image_derivadas; It: in image_derivadas; mediau: in image_19bits; mediav: in image_19bits; dividendo2: out image_19bits ); end component; component second_iteration port( clk: in bit; divisor: in image_19bits; dividendo2: in image_19bits; mediau: in image_19bits; mediav: in image_19bits; Ix: in image_derivadas; Iy: in image_derivadas; uk2: out image_19bits; vk2: out image_19bits ); end component; component medias_2 port( clk: in bit; uk2: in image_19bits; vk2: in image_19bits; mediau2: out image_19bits; mediav2: out image_19bits ); end component; component third_stage_2 port( clk: in bit; Ix: in image_derivadas; Iy: in image_derivadas; It: in image_derivadas; mediau2: in image_19bits; mediav2: in image_19bits; dividendo3: out image_19bits ); end component; component third_iteration port( clk: in bit; divisor: in image_19bits; dividendo3: in image_19bits; mediau2: in image_19bits; mediav2: in image_19bits; Ix: in image_derivadas; Iy: in image_derivadas; uk3: out image_19bits; vk3: out image_19bits ); end component; begin U1: inicializacao PORT MAP ( clk=> clk_0, imagem=> entrada, imagemanterior => entradaanterior ); U2: stage_1 PORT MAP ( clk => clk_0, imagem =>entrada, imagemanterior => entradaanterior, Ix=> Ix_0, Iy=>IY_0, It=>IT_0 ); U3: stage_2 PORT MAP ( clk => clk_0, Ix =>Ix_0, Iy =>Iy_0, It => It_0, divisor => divisor_0, dividendo => dividendo_0 ); U4: first_iteration PORT MAP ( clk => clk_0, divisor => divisor_0, dividendo => dividendo_0, Ix => Ix_0, Iy=> Iy_0, uk1 => uk_0, vk1 => vk_0 --uk1 => ukfinal, --vk1 => vkfinal ); U5: medias_1 PORT MAP( clk => clk_0, uk1 => uk_0, vk1 => vk_0, mediau => mediau_0, mediav =>mediav_0 ); U6: second_stage_2 PORT MAP( clk => clk_0, Ix => Ix_0, Iy => Iy_0, It => It_0, mediau => mediau_0, mediav => mediav_0, dividendo2 => dividendo2_0 ); U7: second_iteration PORT MAP( clk => clk_0, divisor => divisor_0, dividendo2 => dividendo2_0, mediau => mediau_0, mediav => mediav_0, Ix => Ix_0, Iy => Iy_0, uk2 => uk2_0, vk2 => vk2_0 ); U8: medias_2 PORT MAP( clk => clk_0, uk2 => uk2_0, vk2 => vk2_0, mediau2 => mediau2_0, mediav2 =>mediav2_0 ); U9: third_stage_2 PORT MAP( clk => clk_0, Ix => Ix_0, Iy => Iy_0, It => It_0, mediau2 => mediau2_0, mediav2 => mediav2_0, dividendo3 => dividendo3_0 ); U10: third_iteration PORT MAP( clk => clk_0, divisor => divisor_0, dividendo3 => dividendo3_0, mediau2 => mediau2_0, mediav2 => mediav2_0, Ix => Ix_0, Iy => Iy_0, uk3 => uk3_0, vk3 => vk3_0 ); end behavioral;
