DrewBaden's avatar
DrewBaden
7 years ago
Quartus 2 and Modelsim-Altera problem on Windows 10
When I run Modelsim-Altera from inside Quartus 2, after Elaboration, Synthesis, etc, it fails inside Modelsim-Altera and complains that rtl_work is empty. And sure enough, it is. The .do file that creates the directory is created when Modelsim starts up. Here's the output from the Modelsim-Altera transcript, below. Apparently what does is first delete rtl_work if it's already there, then vlib specifies that rtl_work will be the library directory, and then vmap maps its "work" directory to rtl_work. the program vlog then builds it. At least, that's my understanding. But the problem is that the command
vmap work rtl_work
doesn't work. It doesn't happen. So vlog cannot find it.
I don't know how vmap works, but I have feeling this is a windows 10 problem, since this worked ok when I was using windows 7.
Any help?
# Reading D:/Altera/13.1/modelsim_ase/tcl/vsim/pref.tcl
# do top_run_msim_rtl_verilog.do
# if {[file exists rtl_work]} {
# vdel -lib rtl_work -all
# vlib rtl_work
# vmap work rtl_work
# Copying D:\Altera\13.1\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini
# Modifying modelsim.ini
# ** Warning: Copied D:\Altera\13.1\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini.
# Updated modelsim.ini.
# vlog -vlog01compat -work work +incdir+C:/Users/drew/rpi_de3_vC {C:/Users/drew/rpi_de3_vC/uart_tx.v}
# Model Technology ModelSim ALTERA vlog 10.1d Compiler 2012.11 Nov 2 2012
# ** Error: (vlog-19) Failed to access library 'work' at "work".
# No such file or directory. (errno = ENOENT)
# ** Error: D:/Altera/13.1/modelsim_ase/win32aloem/vlog failed.
# Error in macro ./top_run_msim_rtl_verilog.do line 8
# D:/Altera/13.1/modelsim_ase/win32aloem/vlog failed.
# while executing
# "vlog -vlog01compat -work work +incdir+C:/Users/drew/rpi_de3_vC {C:/Users/drew/rpi_de3_vC/uart_tx.v}"
1 Reply
  • DrewBaden's avatar
    DrewBaden
    I think I found the problem. At least, I found a workaround. It might be a windows 10 issue. What I had to do is right click on the C drive, and change all the permissions to "Full Control". Then log out and log back in. Seems to work.
