DrewBaden
7 years agoQuartus 2 and Modelsim-Altera problem on Windows 10
When I run Modelsim-Altera from inside Quartus 2, after Elaboration, Synthesis, etc, it fails inside Modelsim-Altera and complains that rtl_work is empty. And sure enough, it is. The .do file that ...
DrewBaden
7 years agoI think I found the problem. At least, I found a workaround. It might be a windows 10 issue. What I had to do is right click on the C drive, and change all the permissions to "Full Control". Then log out and log back in. Seems to work.
