Quartus 18.1 fitter crash
Sometimes (after minor changes) during project compilation fitter crashes with an error:
Error:
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_legality_pincount.c, Line: 1332
Internal Error
Stack Trace:
0x573ec0: vpr_qi_jump_to_exit + 0x70 (fitter_vpr20kmain)
0xf20b7: vpr_exit_at_line + 0x97 (fitter_vpr20kmain)
0xf2100: handle_assertion_failure_stripped + 0x30 (fitter_vpr20kmain)
0x930e9: cl_legality_pincount_block_list_legal_for_inputs_and_outputs + 0x239 (fitter_vpr20kmain)
0x69470: l_block_list_feasible_with_specified_inputs + 0x150 (fitter_vpr20kmain)
0x69ccb: l_block_list_feasible_with_default_inputs_vpr_engine + 0xcb (fitter_vpr20kmain)
0x6646f: cl_block_list_and_first_ale_position_feasible_with_default_inputs + 0x1cf (fitter_vpr20kmain)
0x4a33f: l_anneal_try_ale_swap + 0x23f (fitter_vpr20kmain)
0x4a00f: l_anneal_try_pair_swaps + 0x20f (fitter_vpr20kmain)
0x4820f: l_anneal_prl_try_pair_swaps + 0x9f (fitter_vpr20kmain)
0x19e825: l_smid_job_thread_fn + 0x75 (fitter_vpr20kmain)
0x5c49cd: l_thread_start_wrapper + 0x3d (fitter_vpr20kmain)
0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16660: mem_thread_wrapper + 0x70 (ccl_mem)
0x2791: thr_thread_begin + 0xa1 (ccl_thr)
0x1570c: BaseThreadInitThunk + 0xc (kernel32)
0x5385c: RtlUserThreadStart + 0x1c (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 7
OS version: 6.1
Quartus Prime Information
Address bits: 64
Version: 18.1.0
Build: 625
Edition: Standard Edition
Device: Cyclone V 5CEFA9F23I7
Deletting db doesn't help. Different fitter settings also doesn't work.
Hi Eugene,
Please let me know if you are able to resolve this using below suggestion.
Update:
I am able to pin down the IE is triggered during heuristic accounting of input pins to a cluster. This heuristic counting is used to generate packing that give more flexibility for router to resolve local congestions for outlier designs, so it should be generally safe to disable this. I have tried the INI to disable this algorithm and the design is able to compile successfully.
Here is the encrypted INI (copy and paste this ini in your qsf) for 21.1 std (encrypted INI support is only avaliable for 20.1std or newer) then recompile.
ini_password = 0f56f88f5713676e261178731ef27f42b49cd891b355d81b400032576444751330035221150003342320131030052576
- IntelSupport
Contributor
Hi Eugene,
Update:
- SyafieqS
Hi Eugene,
I can see you are using EOL Window 7 which might be hard to support. Is it possible to migrate to Win 10 and see if this resolve?
- SyafieqS
May I know if previous reply is feasible?
- EugeneF
Sorry for the late answer. I tried to check it on computer with Win 10 a also upgrade Quartus to 21.1. But the problem remains the same. Nothing changes.
Problem Details
Error:
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_legality_pincount.c, Line: 1332Internal ErrorStack Trace:0x5d30d0: vpr_qi_jump_to_exit + 0x80 (fitter_vpr20kmain)0x106cda: vpr_exit_at_line + 0x8a (fitter_vpr20kmain)0x106d20: handle_assertion_failure_stripped + 0x30 (fitter_vpr20kmain)0x9fa65: cl_legality_pincount_block_list_legal_for_inputs_and_outputs + 0x255 (fitter_vpr20kmain)0x73ed0: l_block_list_feasible_with_specified_inputs + 0x150 (fitter_vpr20kmain)0x7473a: l_block_list_feasible_with_default_inputs_vpr_engine + 0xca (fitter_vpr20kmain)0x7152e: cl_block_list_and_first_ale_position_feasible_with_default_inputs + 0x1ce (fitter_vpr20kmain)0x51da8: l_anneal_try_ale_swap + 0x208 (fitter_vpr20kmain)0x51ab1: l_anneal_try_pair_swaps + 0x211 (fitter_vpr20kmain)0x4fd6f: l_anneal_prl_try_pair_swaps + 0x9f (fitter_vpr20kmain)0x1bf7e5: simd_job_wait + 0x95 (fitter_vpr20kmain)0x50347: l_anneal_prl_perform_temperature + 0x597 (fitter_vpr20kmain)0x4c447: anneal_clustering + 0x657 (fitter_vpr20kmain)0x4585f: cl_build_cluster_of_block_from_scratch + 0x75f (fitter_vpr20kmain)0x39996: do_clustering + 0x4e6 (fitter_vpr20kmain)0x7e126: cl_flow_pack_to_cbes_2 + 0x816 (fitter_vpr20kmain)0x7d816: cl_flow_pack_to_cbes + 0x96 (fitter_vpr20kmain)0x297abc: l_do_clustering_phase + 0x18c (fitter_vpr20kmain)0x296e14: aa_flow_place + 0x64 (fitter_vpr20kmain)0x296aec: aa_flow_fit + 0x11c (fitter_vpr20kmain)0x5d27e9: VPR_QI_FACADE::vpr_qi_main + 0x69 (fitter_vpr20kmain)0x3ce20: fitapi_run_vpr + 0x90 (fitter_fitapi)0x207ff: FSV_EXPERT_BASE::run_vpr + 0x13f (fitter_fsv)0x20229: FSV_EXPERT_BASE::place_and_route + 0x139 (fitter_fsv)0x1f677: FSV_EXPERT_BASE::invoke_fitter + 0x617 (fitter_fsv)0x1d282: fsv_execute + 0x22 (fitter_fsv)0xf01c: fmain_start + 0x8ac (FITTER_FMAIN)0x36ab: qfit_execute_fit + 0x1c7 (comp_qfit_legacy_flow)0x48d8: QFIT_FRAMEWORK::execute + 0x2b4 (comp_qfit_legacy_flow)0x1afb: qfit_legacy_flow_run_legacy_fitter_flow + 0x1c3 (comp_qfit_legacy_flow)0x14640: TclInvokeStringCommand + 0xf0 (tcl86)0x16442: TclNRRunCallbacks + 0x62 (tcl86)0x17c4d: TclEvalEx + 0x9ed (tcl86)0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)0xa5136: Tcl_EvalFile + 0x36 (tcl86)0x127c0: qexe_evaluate_tcl_script + 0x340 (comp_qexe)0x11a6d: qexe_do_tcl + 0x2fd (comp_qexe)0x16c9e: qexe_run_tcl_option + 0x5ee (comp_qexe)0x369f1: qcu_run_tcl_option + 0xdd1 (comp_qcu)0x16599: qexe_run + 0x309 (comp_qexe)0x17641: qexe_standard_main + 0xc1 (comp_qexe)0x2092: qfit2_main + 0x82 (quartus_fit)0x13638: msg_main_thread + 0x18 (CCL_MSG)0x1494e: msg_thread_wrapper + 0x6e (CCL_MSG)0x18520: mem_thread_wrapper + 0x70 (ccl_mem)0x12df1: msg_exe_main + 0xa1 (CCL_MSG)0x2c88: __scrt_common_main_seh + 0x11c (quartus_fit)0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)0x526a0: RtlUserThreadStart + 0x20 (ntdll)End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Address bits: 64
Version: 21.1.1
Build: 850
Edition: Standard Edition - SyafieqS
Is it possible to attach the design in qar for me to reproduce?
This seem to me a legit bug. we need a design to further investigate and possibly provide a workaround.
- EugeneF
Unfortunately I can not send a design because of our company policy.
I try to change a design and compiler settings to find exact cause of error, but I still don't succeed with that.
Can you help me to find possible error causes, according to file and functions where it happens, from the report?
- SyafieqS
If the design cannot be shared, is small test design possible to be created at your end? replicating the issue.
Or you can send your compilation database without sending the source design files? may follow below link on how to do that.
https://www.intel.com/content/www/us/en/support/programmable/articles/000076181.html
Quartus database at least will give some hint to move this forward.
- EugeneF
Small parts of the design doesn't reproduce the issue. Only all design gives that error.
I've attached database, maybe it helps.
- SyafieqS
Thanks for the database. I am checking this with engineering team. Will get back to you once there is any update
- SyafieqS
I am still pending reply regarding the issue. Might take sometimes due to holiday seasons.
- SyafieqS
Hello Eugene,
I am pending from developer and it has been assigned to right person.
Will let you know if there is any update.
