Quartus 18.1 fitter crash
- 3 years ago
Hi Eugene,
Please let me know if you are able to resolve this using below suggestion.
Update:
I am able to pin down the IE is triggered during heuristic accounting of input pins to a cluster. This heuristic counting is used to generate packing that give more flexibility for router to resolve local congestions for outlier designs, so it should be generally safe to disable this. I have tried the INI to disable this algorithm and the design is able to compile successfully.
Here is the encrypted INI (copy and paste this ini in your qsf) for 21.1 std (encrypted INI support is only avaliable for 20.1std or newer) then recompile.
ini_password = 0f56f88f5713676e261178731ef27f42b49cd891b355d81b400032576444751330035221150003342320131030052576
If the design cannot be shared, is small test design possible to be created at your end? replicating the issue.
Or you can send your compilation database without sending the source design files? may follow below link on how to do that.
https://www.intel.com/content/www/us/en/support/programmable/articles/000076181.html
Quartus database at least will give some hint to move this forward.
Small parts of the design doesn't reproduce the issue. Only all design gives that error.
I've attached database, maybe it helps.
