Serdyuk's avatar
Serdyuk
3 years ago
quartus 18.1 crashes during Analysis& Synthesis when Signal tap is added
No matter what signal I add to Signal Tap I get this error:
Problem Details
Error:
Internal Error: Sub-system: PDB, File: /quartus/db/pdb/pdb_error.cpp, Line: 53
stsize <= UINT_MAX
Stack Trace:
     0x46ad: err_report_internal_error + 0x2d (CCL_ERR)
    0x11388: pdb_internal_error + 0x54 (DB_PDB)
     0xaf48: operator<<<PDB_CDB_SEG_BASE,CDB_ATOM_ITERM * __ptr64> + 0x88 (db_cdb_atom)
    0x11fe3: CDB_ATOM_NODE::operator<< + 0x4bb (db_cdb_atom)
     0x7d45: CDB_ATOM_CUDA_LCELL_COMB::operator<< + 0x5d (db_cdb_atom_cuda)
     0x2301: PDB_SEGMENT_WRITER::finish_writing_all + 0xb1 (DB_PDB)
     0x86b4: pdb_write_ptr + 0x12c (DB_PDB)
    0x45c2e: pdb_write<PDB_ARCHIVE,CDB_CHIP_DB_ENTRY> + 0x4e (db_qtk)
    0x560a7: QTK_QIC_PDB<CDB_CHIP_DB_ENTRY>::write_file + 0xd7 (db_qtk)
    0x1e4dc: qsyn_write_incremental_results + 0x8ec (quartus_map)
    0x22a4e: QSYN_FRAMEWORK::write_qic_databases + 0x17e (quartus_map)
    0x21f44: QSYN_FRAMEWORK::write_databases + 0x114 (quartus_map)
    0x11378: qexe_do_normal + 0x2a8 (comp_qexe)
    0x16142: qexe_run + 0x432 (comp_qexe)
    0x16e51: qexe_standard_main + 0xc1 (comp_qexe)
    0x1b08b: qsyn_main + 0x51b (quartus_map)
    0x12e98: msg_main_thread + 0x18 (CCL_MSG)
    0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG)
    0x16660: mem_thread_wrapper + 0x70 (ccl_mem)
    0x12761: msg_exe_main + 0xa1 (CCL_MSG)
    0x29872: __tmainCRTStartup + 0x10e (quartus_map)
    0x526b0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_map
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 18.1.0
Build: 625
Edition: Lite Edition
  • Nurina's avatar
    Nurina
    Thank you for using Intel Communities.
    Since this is an old version of Quartus, I suggest that you use the latest available Quartus version since most bugs are fixed in the latest version.
    Please try Quartus Lite 22.1.
    Let me know if there are any problems.
    Nurina
  • Nurina's avatar
    Nurina
    We have not received a reply from you. As such, I now transition this thread to community support. If you have a new question, Feel free to open a new thread or login to ‘ https://supporttickets.intel.com ’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    Please let me know of any inconvenience so that I may improve your future service experience.
    Have a great day!
    Nurina W.
