SDe_J's avatar
SDe_J
6 years ago
Quartus 18.1 and 19.1 unable to program stratix 10 L-tile
I think this is a bug, but I'm not sure where to post bug reports.
I have been unable to program my stratix 10 L-tile dev kit (1SG280LU2F50E2VGS3) with either quartus pro 18.1 or 19.1.
I can program with pro 18.0 only. A project made and compiled in 18.0 will fail to program in 18.1. The progress bar stalls at 10% and fails with this error message
Info(209060): Started Programmer operation at Thu Jun 20 10:09:46 2019
Info(18942): Configuring device index 2
Error(18950): Device has stopped receiving configuration data
Error(18948): Error message received from device: Device is in configuration state.
Error(209012): Operation failed
Info(209061): Ended Programmer operation at Thu Jun 20 10:09:58 2019
I then need to power cycle the board to reprogram it with 18.0
To summarize, I can only compile and program a project for the L-tile with one version of quartus pro: 18.0
  • JohnT_Altera's avatar
    JohnT_Altera
    I observed that you are using 1SG280LU2F50E2VG in your project rather than 1SG280LU2F50E2VGS3 which is on your board. I would recommend you to change the device to the correct one.
