10 years agoQuartus 15.1 requires libpng12 ?
I have just installed Quartus 15.1 64-bit edition on a Linux machine. Starting quartus gave me : quartus: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory Why does Quartus still need libpng 12 ? This is an old library. How can I resolve this ? best regards Simon12 Replies
Problem: libpng12 not present or not linked<=Ubuntu 14.04 and newer Linux OS usually use libpng16+ or not even present in the repositories
Solution: Install libpng12<=Canonical repositories are no longer supporting libpng12=>https://packages.debian.org/es/jessie/libpng12-0 download the package(only .deb for debian base OS) - Altera_Forum
Hi
I too had the same issue with Quartus 15.1, in Ubuntu 17.04 (GNU/Linux 4.10.0-35-generic x86_64) "error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory" Solution 1) download libpng12-0_1.2.50-2+deb8u3_amd64.deb, from https://packages.debian.org/es/jessie/amd64/libpng12-0/download 2) dpkg -i libpng12-0_1.2.50-2+deb8u3_amd64.deb After this Quartus open up with GUI...!
