Azimath
3 years agoQuartus 13.1 stuck at Fitter when compiling on Linux
OS: Archlinux
Quartus Version: 13.1.0 build 162
Device: EP4CE115F29C7
Hi, as the title says. I have problem with the compilation. I can compile my code on device that has fewer LEs as far as i ...
RichardT_altera
3 years agoMy advice is to run the design first using the latest supported Quartus version, for the device you are using, to see if the issue persists. Cause a lot of bug have been fixed throughout the years.
If the design able to pass in newer Quartus version, the chances to get the support to fix the older software tool is usually none.
Richard Tan
