11 years agoHi,
The same happens to me also on latest Quartus 14.0.1 on Windows 7 system. problem details Error: Internal Error: Sub-system: TIS, File: /quartus/tsm/tis/tis_physical_timing_api.cpp, Line: 4396 Found Physical Timing arcs with no logical equivalent. Need to create a derived class to handle these arcs Stack Trace: 0x6682a: TIS_RE_DELAY_TREE_NETLIST::is_itt_starting_point + 0x67ba 0x63edd: TIS_RE_DELAY_TREE_NETLIST::is_itt_starting_point + 0x3e6d 0x629b8: TIS_RE_DELAY_TREE_NETLIST::is_itt_starting_point + 0x2948 0x6d2dd: TIS_RE_DELAY_TREE_NETLIST::is_itt_starting_point + 0xd26d 0x6e1ce: TIS_RE_DELAY_TREE_NETLIST::is_itt_starting_point + 0xe15e 0x6e578: TIS_RE_DELAY_TREE_NETLIST::is_itt_starting_point + 0xe508 0x51ce0: TIS_MANAGER_IMPL::annotate_bcm_netlist + 0x170 0xfa4a: TAPI_ROOT_IMPL::annotate_non_pll_atoms + 0x4aa 0x9400: TAPI_ROOT_IMPL::start + 0x350 0x9c0d: TAPI_ROOT_IMPL::start + 0x7d 0x9ef3: TAPI_ROOT::start + 0xc3 0xb8871: FITCC_TDC_UTILITY::initialize_dat + 0x621 0xb8acc: FITCC_TDC_UTILITY::setup_tdc_utility + 0xbc 0xbaea2: FITCC_TDC_UTILITY::FITCC_TDC_UTILITY + 0x252 0x3f65f: FITCC_ENV::get_tdc_utility_or_create_if_necessary + 0x35f 0x2763b: FSV_REGISTER_PACKER_OP_INTERFACE::create_register_packer_legality_listeners + 0xe4b 0x1d698: FSV_U2B_POSTFIT::operator= + 0x62c8 0x144cf: fsv_initialize_fitter + 0x9af 0x163f8: fsv_initialize_fitter + 0x28d8 0x168a9: fsv_initialize_fitter + 0x2d89 0x13ac2: fsv_execute + 0x22 0xb909: fmain_start + 0x809 0x266c: Legacy_fitter_Init + 0x15fc 0x16ad: Legacy_fitter_Init + 0x63d 0x1b6b: Legacy_fitter_Init + 0xafb 0xf8a6: TclInvokeStringCommand + 0xc6 0x112a8: TclEvalObjvInternal + 0x328 0x121b5: TclEvalEx + 0x8d5 0x12d48: TclEvalObjEx + 0x2d8 0x1abbd: Tcl_EvalObjCmd + 0xfd 0x112a8: TclEvalObjvInternal + 0x328 0x56917: TclExecuteByteCode + 0xe47 0xa2376: TclObjInterpProcCore + 0x76 0x112a8: TclEvalObjvInternal + 0x328 0x56917: TclExecuteByteCode + 0xe47 0xa2376: TclObjInterpProcCore + 0x76 0x112a8: TclEvalObjvInternal + 0x328 0x121b5: TclEvalEx + 0x8d5 0x7c117: Tcl_FSEvalFileEx + 0x1d7 0x7a626: Tcl_EvalFile + 0x36 0xb172: qexe_evaluate_tcl_command + 0xac2 0x104fc: qexe_get_command_line + 0xf5c 0x12f8d: qexe_run_tcl_option + 0x44d 0x1b4ae: qcu_run_tcl_option + 0xace 0x1358b: qexe_process_cmdline_arguments + 0x54b 0x136f1: qexe_standard_main + 0xa1 0x9678: msg_exe_fini + 0x58 0x978c: msg_exe_fini + 0x16c 0x12c4: MEM_INITIALIZER::~MEM_INITIALIZER + 0x184 0xabe9: msg_exe_main + 0x99 0x1652c: BaseThreadInitThunk + 0xc 0x2c540: RtlUserThreadStart + 0x20 End-trace Executable: quartus_fit Comment: None system information Platform: windows64 OS name: Windows 7 OS version: 6.1 quartus ii information Address bits: 64 Version: 14.0.1 Build: 205 Edition: Web Edition
