12 years ago
Quartus 13.0sp1 TimeQuest Worst Case Paths
I recently started using Quartus 13.0sp1. Previously I was using much older versions of Quartus, so I have not yet become familiar with the layout changes in these later versions.
I have a design that is not meeting timing, but I can't figure out how to get quartus to include in the report file the worst case paths. I turned on the "Report worst-case paths during compilation" setting found in the settings - timequest timing analyzer window. But I don't see where the worst-case paths are listed in the compilation report?
I would appreciate anyone who could point me in the right direction.
-kstolp
    open Tools > TimeQuest Timing Analyzer
    then scroll in the Tasks window and double click Report Top Failing Paths
    What does the "Report worst-case paths during compilation" setting do?
    it doesn't look all that useful, it just puts more detailed information about the top failing path into the TimeQuest report that gets output to the console during compilation
    with switch OFF:
    Info (332146): Worst-case minimum pulse width slack is -0.146
    Info (332119): Slack End Point TNS Clock
    Info (332119): ========= ============= =====================
    Info (332119): -0.146 -10.364 clk
    with switch ON:
    Info (332115):
    Info (332113): Report Minimum Pulse Width: Found 1 results (1 violated). Worst case slack is -0.146
    Info (332113): Targets: [get_clocks {clk}]
    Info (332113): -nworst: 1
    Info (332113): -detail: full_path
    Info (332113): Path# 1: slack is -0.146 (VIOLATED)
    Info (332113): ===================================================================
    Info (332113): Node : divider_r[0]
    Info (332113): Clock : clk
    Info (332113): Type : Low Pulse Width
    Info (332113):
    Info (332113): Late Clock Arrival Path:
    Info (332113):
    Info (332113): Total (ns) Incr (ns) Type Element
    Info (332113): ========== ========= == ==== ===================================
    Info (332113): 0.500 0.500 launch edge time
    Info (332113): 0.500 0.000 source latency
    Info (332113): 0.500 0.000 clk
    Info (332113): 0.500 0.000 FF IC clk~input|i
    Info (332113): 1.093 0.593 FF CELL clk~input|o
    Info (332113): 1.372 0.279 FF IC clk~inputclkctrl|inclk
    Info (332113): 1.481 0.109 FF CELL clk~inputclkctrl|outclk
    Info (332113): 2.597 1.116 FF IC divider_r[0]|clk
    Info (332113): 2.711 0.114 FF CELL divider_r[0]
    Info (332113):
    Info (332113): Early Clock Arrival Path:
    Info (332113):
    Info (332113): 1.000 1.000 launch edge time
    Info (332113): 1.000 0.000 source latency
    Info (332113): 1.000 0.000 clk
    Info (332113): 1.000 0.000 RR IC clk~input|i
    Info (332113): 1.299 0.299 RR CELL clk~input|o
    Info (332113): 1.563 0.264 RR IC clk~inputclkctrl|inclk
    Info (332113): 1.666 0.103 RR CELL clk~inputclkctrl|outclk
    Info (332113): 2.769 1.103 RR IC divider_r[0]|clk
    Info (332113): 2.846 0.077 RR CELL divider_r[0]
    Info (332113): 2.898 0.052 clock pessimism
    Info (332113):
    Info (332113): Required Width : 0.333
    Info (332113): Actual Width : 0.187
    Info (332113): Slack : -0.146 (VIOLATED)
    Thank you for the info. The report top failing paths has the information I was looking for.
