12 years agoit doesn't look all that useful, it just puts more detailed information about the top failing path into the TimeQuest report that gets output to the console during compilation
with switch OFF: Info (332146): Worst-case minimum pulse width slack is -0.146 Info (332119): Slack End Point TNS Clock Info (332119): ========= ============= ===================== Info (332119): -0.146 -10.364 clk with switch ON: Info (332115): Info (332113): Report Minimum Pulse Width: Found 1 results (1 violated). Worst case slack is -0.146 Info (332113): Targets: [get_clocks {clk}] Info (332113): -nworst: 1 Info (332113): -detail: full_path Info (332113): Path# 1: slack is -0.146 (VIOLATED) Info (332113): =================================================================== Info (332113): Node : divider_r[0] Info (332113): Clock : clk Info (332113): Type : Low Pulse Width Info (332113): Info (332113): Late Clock Arrival Path: Info (332113): Info (332113): Total (ns) Incr (ns) Type Element Info (332113): ========== ========= == ==== =================================== Info (332113): 0.500 0.500 launch edge time Info (332113): 0.500 0.000 source latency Info (332113): 0.500 0.000 clk Info (332113): 0.500 0.000 FF IC clk~input|i Info (332113): 1.093 0.593 FF CELL clk~input|o Info (332113): 1.372 0.279 FF IC clk~inputclkctrl|inclk Info (332113): 1.481 0.109 FF CELL clk~inputclkctrl|outclk Info (332113): 2.597 1.116 FF IC divider_r[0]|clk Info (332113): 2.711 0.114 FF CELL divider_r[0] Info (332113): Info (332113): Early Clock Arrival Path: Info (332113): Info (332113): Total (ns) Incr (ns) Type Element Info (332113): ========== ========= == ==== =================================== Info (332113): 1.000 1.000 launch edge time Info (332113): 1.000 0.000 source latency Info (332113): 1.000 0.000 clk Info (332113): 1.000 0.000 RR IC clk~input|i Info (332113): 1.299 0.299 RR CELL clk~input|o Info (332113): 1.563 0.264 RR IC clk~inputclkctrl|inclk Info (332113): 1.666 0.103 RR CELL clk~inputclkctrl|outclk Info (332113): 2.769 1.103 RR IC divider_r[0]|clk Info (332113): 2.846 0.077 RR CELL divider_r[0] Info (332113): 2.898 0.052 clock pessimism Info (332113): Info (332113): Required Width : 0.333 Info (332113): Actual Width : 0.187 Info (332113): Slack : -0.146 (VIOLATED) Info (332113): ===================================================================
