11 years agoQuartus 12252 Error
Hi everyone,
I have cyclone v gt dev. kit from altera. I want to reconfigure the system controller, namely max v cpld. Altera supply all the design files about the max v on the board. The problem start here. When I open the quartus project and try to systhesis, I get lots of error with same error code. The error given by quartus is as following: warning (12251): q_sys.: quartus ii 32-bit generate hdl interface was successful. 0 errors, 0 warnings error (12252): q_sys.: port reset_n has type std_logic which is not supported error (12252): q_sys.: port clk has type std_logic which is not supported error (12252): q_sys.: port clk_pls_p has type std_logic which is not supported error (12252): q_sys.: port address has type std_logic_vector which is not supported error (12252): q_sys.: port write_n has type std_logic which is not supported error (12252): q_sys.: port read_n has type std_logic which is not supported error (12252): q_sys.: port waitrequest_n has type std_logic which is not supported error (12252): q_sys.: port data_in has type std_logic_vector which is not supported error (12252): q_sys.: port data_out has type std_logic_vector which is not supported warning (12251): q_sys.: quartus ii 32-bit generate hdl interface was successful. 0 errors, 0 warnings error (12252): q_sys.: port reset_n has type std_logic which is not supported error (12252): q_sys.: port clk has type std_logic which is not supported error (12252): q_sys.: port mstr_en_n has type std_logic which is not supported error (12252): q_sys.: port mstr_address has type std_logic_vector which is not supported error (12252): q_sys.: port mstr_write_n has type std_logic which is not supported error (12252): q_sys.: port mstr_read_n has type std_logic which is not supported error (12252): q_sys.: port mstr_data_in has type std_logic_vector which is not supported error (12252): q_sys.: port mstr_data_out has type std_logic_vector which is not supported error (12252): q_sys.: port mstr_waitrequest_n has type std_logic which is not supported error (12252): q_sys.: port slv_en_n has type std_logic which is not supported error (12252): q_sys.: port slv_address has type std_logic_vector which is not supported error (12252): q_sys.: port slv_read_n has type std_logic which is not supported error (12252): q_sys.: port slv_write_n has type std_logic which is not supported error (12252): q_sys.: port slv_data_in has type std_logic_vector which is not supported error (12252): q_sys.: port slv_data_out has type std_logic_vector which is not supported error (12252): q_sys.: port slv_waitrequest_n has type std_logic which is not supported warning (12251): q_sys.: quartus ii 32-bit shell was successful. 0 errors, 0 warnings warning (12251): q_sys.: quartus ii 32-bit generate hdl interface was successful. 0 errors, 0 warnings error (12252): q_sys.: port wb_clk_i has type std_logic which is not supported error (12252): q_sys.: port wb_rst_i has type std_logic which is not supported error (12252): q_sys.: port wb_adr_i has type std_logic_vector which is not supported error (12252): q_sys.: port wb_dat_i has type std_logic_vector which is not supported error (12252): q_sys.: port wb_dat_o has type std_logic_vector which is not supported error (12252): q_sys.: port wb_we_i has type std_logic which is not supported error (12252): q_sys.: port wb_stb_i has type std_logic which is not supported error (12252): q_sys.: port wb_ack_o has type std_logic which is not supported error (12252): q_sys.: port wb_inta_o has type std_logic which is not supported error (12252): q_sys.: port scl_pad_io has type std_logic which is not supported error (12252): q_sys.: port sda_pad_io has type std_logic which is not supported
Are there any body who faced with same problem? Thanks in advance. Sinan.
Can try with the Quartus II version that the design was created?
Yes, I've tried with both version of quartus.(13.0 and 13.1) Project created with 13.0.
Since the error is generated even when you are using the original file provided by Altera. I think you should contact MySupport to check with Altera if there is any missing file.
