11 years agoYour code requires memory access in two separate processes, one for write and one for read.
This possibly implies the compiler can't infer a simple synchronous ram, and it could implement far more logic than what is actually required. Probably it implements a dual port ram or it infers latched to cover all data paths. Please follow the guidelines in this document for inferring ram functions: http://www.altera.com/literature/hb/qts/qts_qii51007.pdf (read from page 14)
