13 years agoYou need to be more explicit wrt your linux distribution. 64 bit linux works fine, but some distributions have quirks that must be dealt with.
--- Quote Start --- Hi Guys I have just installed the Quartus 12.1 64-bit Linux on my laptop. I downloaded the modelSim starter version 10.1b that is compatible with the quartus 12.1 from the altera downloads. I went through all the installation guides to set up modelsim and when i go to run the RTL_simulation i get this error; Can't launch modelSim-altera simulation software-- make sure the software is properly install and the environment variables LM_LICENSE_FILE or MGLS_LICENSE_FILE are set. I have noticed that in my directories where i installed the modelsim i don't have a license.dat file. As far as i was aware from reading and some post the modelsim starter shouldn't need licenses. I need to use this to simulate for my final year project so if any one has any ideas that might help me get over this obstacle i would much appreciate it. Is this an issue with me using a 64bit operating system? --- Quote End ---
