13 years agoThank you for sharing this solution! I had the same problem: running Windows 7, 64 bit, I installed Quartus II 12.0 sp2, and even though the USB-Blaster seems fine in the Windows device manager, the Quartus Programmer was not seeing it.
Adding the TBB libraries (I just copied everything out of bin\intel64\vc10 in the TBB zip) to altera\12.0sp2\quartus\bin64 did the trick. Thanks again Pinhedd!
