11 years ago
Quartus 12. --Analysis and Synthesis Failed- Help Needed
Hello here is a small program that I wrote in VHDL(please see attachment). Synthesis fails in Quartus with the following error.
Error[10028]: can't resolve multiple constant drivers for net wr_data[]...
Can someone help me with solve it?
Manoj
    --- Quote Start ---
    Manoj
    --- Quote End ---
    It is telling you you have assigned to write_data in two assignments (the combinatorial logic before stste machine then inside state machine).
    Which one you want?
    Thanks Kaz, for your reply. I would like to assign both the assignments, as I need it for my logic.
    Any idea how to implement it?
    Manoj
    you should assign to wr_data in one construct but check priority.
    wr_data <=  x"00" when state = s1 else
                     x"00" when count_reg = x"00" else
                     x"01" when count_reg = x"01" else
                     x"02" when count_reg = x"02" else
                     x"03" when count_reg = x"03" else
                     x"04" when count_reg = x"04" else
                     x"05" when count_reg = x"05" else
                     x"06" when count_reg = x"06" else
                     x"07" when count_reg = x"07" else
                     x"08" when count_reg = x"08" else
                     x"09" when count_reg = x"09" else
                     x"0A" when count_reg = x"0A" else
                     x"FF";
