12 years agoI know this post is a bit old, but i stumbled upon exactly this issue and figured it deserved a reply.
The permissions change you have listed is one that is floating around the internet, but when i used those same permissions the jtag server had the same lockup behavior. Instead use these rule commands SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="0666" SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6002", MODE="0666" SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6003", MODE="0666" SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6010", MODE="0666" SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6810", MODE="0666" and it will work. If you look at it this makes a bit more sense, what is all that extra stuff doing anyway?
