14 years agoHi Rbugalho,
After a lot of trials, our SW confirmed that the SOF file which is built based on Synplify flow works well. Now, I am trying to use the VQM file(represent CPU) generated by Synplify to build whole chip SOF with Quartus 10.0. My question here is how to configure Quartus not to touch any function in the VQM file? As I understand, Quartus tool will be used for P&R(place and rout) even in the pure Synplify flow. Please correct me if I am not right. So, if pure synplify flow works, there is no reason Quartus+VQM will fail unless some options in the Quartus lead to some modifications in the design of VQM during fitting/P&R ... If need, I can show you global setting in my QSF file. thanks, acme
