14 years agoHi Rbugalho,
It seems "fitting to optimize all paths for hold timing" works!! I can get EJTAG connected now. However, it looks like a side-effect that I can't access to DRAM on the FPGA board any more. The dram clock is derived from fpga_pll (a megafunction, clock ratio is XTAIL*9/2 where XTAIL is a clock source from PAD) and I didn't set any constraint on it. I think dram access problem is a timing issue so here comes a few questions about timing: a. should I use create_clk command on the dram clock? b. how to get timing report of clocks derived from fpga_pll? c. do I have to set any constraint or options for dram clock at this situation? (I mean, with the option fix hold time for ALL PATH) Thanks, Acme
