17 years agoQuartus / Modelsim Compile Order
I am wondering if anybody can tell me how to set the compile order for modelsim. I have created a small test project in VHDL where I directly instantiate an entity (without component declaration VHDL-93).
entity comp_inst is
port
a : in std_logic;
y : out std_logic
end entity;
architecture rtl of comp_inst is
begin
U1: entity work.my_not(rtl) port map (a, y);
end rtl;
When I start Modelsim from Quartus via the "EDA RTL Simulation" command, Quartus is generating a .do script with the following compile order:
vcom -93 -work work {C:/altera/work/comp_inst/comp_inst.vhd}
vcom -93 -work work {C:/altera/work/comp_inst/my_not.vhd}
Modelsim is generating the following error message during compilation.
# vcom -93 -work work {C:/altera/work/comp_inst/comp_inst.vhd}
# Model Technology ModelSim ALTERA vcom 6.4a Compiler 2008.08 Oct 22 2008
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Compiling entity comp_inst
# -- Compiling architecture rtl of comp_inst
# ** Error: (vcom-11) Could not find work.my_not.
# ** Error: C:/altera/work/comp_inst/comp_inst.vhd(14): (vcom-1195) Cannot find expanded name "work.my_not".
# ** Error: C:/altera/work/comp_inst/comp_inst.vhd(14): Unknown expanded name.
# ** Error: C:/altera/work/comp_inst/comp_inst.vhd(15): VHDL Compiler exiting
# ** Error: C:/altera/90/modelsim_ase/win32aloem/vcom failed.
# Error in macro ./comp_inst_run_msim_rtl_vhdl.do line 8
# C:/altera/90/modelsim_ase/win32aloem/vcom failed.
# while executing
# "vcom -93 -work work {C:/altera/work/comp_inst/comp_inst.vhd}"
If I swap the compile order of the two entities and restart the *.do script within Modelsim everything is working fine. Anyway on the next start Quartus has overwritten the modified *.do script. Is there any way to force quartus to generate a script with the right compile order? Thanks! BTW I am using Quartus 9.0 Web Edition and Modelsim Altera Starter Edition 6.4a4 Replies
try "add files" to project in Quartus menu, in the order you want
I changed the order in "Projekt - Add/Remove files in Projekt..." and also tried to change the order in "Project Navigator - Files" sheet but the order in the .do script does not change.
Any other idea? - Altera_Forum
It works if you change the order in the "Project Navigator - Files" sheet and afterwards start the "analysis & synthesis" process.
Thanks for the help! - Altera_Forum
Within modelsim menu use "compile" and select submenu "compile order..."
Best Regards, Johi.
