Quartus : Master clock could not be derived
Can you please attach the design in the forum ? It will helpful to look at more in details
Thank you ,
Sree
Is this enough?
- SreekumarR_G_Intel7 years ago
Thank you for sharing the files ,
Reason I requested for the file that I assumed you already done the constraint manually and getting the this warning. Hence I am curious to know what is going on :) ..
Anyway I noticed you didnt add constraint ,Can you create .sdc file (Add to the project) and add below commands to it . Once I added , those warning went off
derive_pll_clocks -create_base_clocks
derive_clock_uncertainty
create_clock -period 10.000 -name refclk1 -waveform {0 5} [get_ports {clk_ffly0_ref}]
Also Noticed your top module of VHDL is incomplete . (i.e) VHDL based RTL must add the component port and port mapping of those component .
Attached modified top module file for reference.
Thank you,
Sree
- qrive17 years ago
I think "derive_pll_clocks" command is obsolete (with quartus 18.1 pro and stratix 10)
But sorry I wasn't clear : It's just about understanding why, not about solving a concrete case.
My question is exactly on why do I have to define the clk_ffly0_ref for the pll_40 and I don't have to do it for the refclk_100 in the pll_gen. It doesn't seem logic to me.
Since all my clocks are part of a PLL, it should not be necessary to declare any clock (I mean create_clock or create generated clock commands).
Thanks in advance
