15 years agoWhy don't you provide a 'patched' version of "altera_europa_support_lib" file ?
All warnings are derived of following VHD function : -- a_ext is the Altera version of the EXT function. It is used to both -- zero-extend a signal to a new length, and to extract a signal of 'size' -- length from a larger signal. FUNCTION a_ext (arg : STD_LOGIC_VECTOR; size : INTEGER) RETURN STD_LOGIC_VECTOR IS VARIABLE arg_copy : STD_LOGIC_VECTOR ((arg'length - 1)DOWNTO 0) := arg ; VARIABLE result : STD_LOGIC_VECTOR((size-1) DOWNTO 0) := (others => '0'); VARIABLE i : integer := 0; VARIABLE bits_to_copy : integer := 0; VARIABLE arg_length : integer := arg'length ; VARIABLE LSB_bit : integer := 0; BEGIN bits_to_copy := a_min(arg_length, size); FOR i IN 0 TO (bits_to_copy - 1) LOOP result(i) := arg_copy(i); end LOOP; RETURN(result); END;
