Quartus® Prime 90-Day Evaluation License + IPs
A Quartus® Prime 90-Day Evaluation License has been generated, but it does not cover the required Ethernet IP cores:
- Triple-Speed Ethernet – OpenCore Plus (00BD)
- Low Latency 10Gbps Ethernet MAC – OpenCore Plus (0119)
Request: Can temporary/evaluation licenses be issued for these IP cores, and how can they be generated?
- sbj
It is for a Cyclone 10GX project
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
- sstrell
Those IPs are both labeled as supporting OpenCore Plus (I think now it's just called IP Evaluation Mode), so you can design with them, simulate them, and even generate a programming file with them. However, you'll need to stay tethered to your device once you program the board until you purchase a license. Details here:
https://docs.altera.com/r/docs/813669/26.1.1/triple-speed-ethernet-ip-user-guide-agilex-3-and-agilex-5-fpgas-and-socs/ip-evaluation-mode
- ZiYingE_Altera
Contributor
Hi sbj,
Does sstrell reply help address your inquiry?
The Triple-Speed Ethernet IP and Low Latency 10Gbps Ethernet MAC IP support OpenCore Plus (IP Evaluation Mode). Therefore, a separate temporary or evaluation license is not required for evaluation purposes.
You may generate a programming file and evaluate the design without purchasing an IP license. However, the compiler will generate a time-limited programming file (<project_name>_time_limited.sof). Once the evaluation period expires, the FPGA will need to be reprogrammed to continue operation.
If you would like to generate an unrestricted production programming file that does not require periodic reprogramming, a valid purchased IP license is required for the corresponding IP cores. You may purchased the IP licenses via our authorized distributor: https://www.altera.com/contact.
Feel free to let me know if you have any questions or encounter any issues.
Thank you.
ZiYingE_Altera- ZiYingE_Altera
Contributor
Hi sbj,
Just checking in to see if you have any further questions.
Please feel free to let us know if there is anything we can assist with.
Thank you.
ZiYingE_Altera
