Quartus® Prime 90-Day Evaluation License + IPs
Those IPs are both labeled as supporting OpenCore Plus (I think now it's just called IP Evaluation Mode), so you can design with them, simulate them, and even generate a programming file with them. However, you'll need to stay tethered to your device once you program the board until you purchase a license. Details here:
https://docs.altera.com/r/docs/813669/26.1.1/triple-speed-ethernet-ip-user-guide-agilex-3-and-agilex-5-fpgas-and-socs/ip-evaluation-mode
Hi sbj,
Does sstrell reply help address your inquiry?
The Triple-Speed Ethernet IP and Low Latency 10Gbps Ethernet MAC IP support OpenCore Plus (IP Evaluation Mode). Therefore, a separate temporary or evaluation license is not required for evaluation purposes.
You may generate a programming file and evaluate the design without purchasing an IP license. However, the compiler will generate a time-limited programming file (<project_name>_time_limited.sof). Once the evaluation period expires, the FPGA will need to be reprogrammed to continue operation.
If you would like to generate an unrestricted production programming file that does not require periodic reprogramming, a valid purchased IP license is required for the corresponding IP cores. You may purchased the IP licenses via our authorized distributor: https://www.altera.com/contact.
Feel free to let me know if you have any questions or encounter any issues.
Thank you.
ZiYingE_Altera
- ZiYingE_Altera1 month ago
Contributor
Hi sbj,
Just checking in to see if you have any further questions.
Please feel free to let us know if there is anything we can assist with.
Thank you.
ZiYingE_Altera- ZiYingE_Altera1 month ago
Contributor
Hi sbj,
As we have not heard back from you since our last update, we will set this case to close status for now.
If you have any further questions or would like to continue the investigation, please feel free to reply to this case at any time to reopen it.
Thank you, and have a great day!
ZiYingE_Altera
