TSege1's avatar
TSege1
6 years ago
Quartos Prime Pro 19.04 on Ububtu 16.04 LTS - Eclipse crashes on startup "free(): invalid pointer"
Hi All,
I installed Quartos Prime Pro 19.4 on Ububtu 16.04 LTS.
When i run Eclipse, i getting the next Error:
OpenJDK 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
*** Error in `/home/kratos-emi-sw/intelFPGA_pro/19.4/quartus//linux64/jre64/bin/java': free(): invalid pointer: 0x00007f582e37dd60 ***
i am waiting for help
Tamir
  • Hi
    I have a similar error, my solution was to replace Quartus java engine with Java 8
    It must be java 8
    The following workaround seems to work, it essentially replace Quartus included java engine with Java 8
    cd ..../intelFPGA/20.1/quartus/linux64
    mv jre64 jre64_old
    ln -s /lib/jvm/java-1.8.0-openjdk-amd64/jre jre64
    the path to Java 8 jre might be machine specific, mine is at least placed there
  • SThor8's avatar
    SThor8
    Hi
    It must be java 8
    mv jre64 jre64_old
    • TSege1's avatar
      TSege1
      Thank you very much, it's solved my problem!
      Tamir
