TSege1
6 years agoQuartos Prime Pro 19.04 on Ububtu 16.04 LTS - Eclipse crashes on startup "free(): invalid pointer"
Hi All,
I installed Quartos Prime Pro 19.4 on Ububtu 16.04 LTS.
When i run Eclipse, i getting the next Error:
OpenJDK 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was rem...
- 6 years ago
Hi
I have a similar error, my solution was to replace Quartus java engine with Java 8
It must be java 8
The following workaround seems to work, it essentially replace Quartus included java engine with Java 8
cd ..../intelFPGA/20.1/quartus/linux64
mv jre64 jre64_old
ln -s /lib/jvm/java-1.8.0-openjdk-amd64/jre jre64the path to Java 8 jre might be machine specific, mine is at least placed there
SThor8
6 years agoHi
It must be java 8
mv jre64 jre64_old
TSege1
6 years agoThank you very much, it's solved my problem!
Tamir
