13 years ago --- Quote Start --- Hello, in my case the problem was related to the window paths exceeding the ~260 limit. Make sure the path name for the Quartus project, QSYS output generation directory and Nios II project name are as short as possible so that the total path name will not exceed window path limit. Also, Quartus 13.0 now has a key new feature, it now (finally) supports VHDL bus functional models (BFMs) Saber890 --- Quote End --- Yes, thank you very much. This was the annoying problem :-) Very stumbling! Luca
