TZhao3
6 years agoQsys (Platform Designer) Cannot Find hps_sdram_p0_altdqdqs.v
I'm generating RTL with the Platform Designer for a DE1-SoC board. I use an Cyclone V HPS IP and an altera_avalon_new_sdram_controller IP. When generating RTL, I received the following error: Error...
TZhao3
6 years agoHi KTan_Intel,
I actually have the make command installed, and build-essential as well. However, the same issue keeps on popping up.
Another experiment I did was to create a clean project and re-import the .qsys file, and then generate RTL. This time the same error didn't show up; but if I were to slightly modify the qsys project and regenerate the RTL code, the same "border" error would show up from time to time. Do you happen to know what the cause could be? For now, I can do a temporary fix that cleans up the project before generating RTL every time.
